11-11-2022
09:33
10:38
DavideFitbit
11-11-2022
09:33
10:38
DavideFitbit
Hi, out of nowhere my Charge 5 wont sync with the app anymore. However it is still sending me notifications from my phone (even these are coming late). It seems like there is a one way connection between the devices. Anyone knows how to fix this? for the record this happened once before but the matter solved itself. However, its been 3 days now since it hasn't synced.
Moderator edit: format
Best Answer11-24-2022 10:37
11-24-2022 10:37
Hi, welcome back to the Community forums, @Capt_Clay10.
I appreciate all the information that you've shared about the difficulty you're experiencing with your Charge 5.
If you haven't done so already, please try the following steps that have been useful for other users:
In addition, I recommend that you try restarting the device using the three pulse restart method:
If you're still having any issues, let me know if you already tried all the steps listed here to resolve syncing problems, and make sure to check the compatibility requirements listed here and to keep the Fitbit app updated to the latest version available.
Hope this helps, I'll be around.
