03-02-2023
01:04
07:47
DavideFitbit
03-02-2023
01:04
07:47
DavideFitbit
Replaced old Charge 3 with a Charge 5 few weeks ago. It's stopped syncing happens every couple of days . I've had a charge 3 for years so know all the usual fixes. Unreliable to say the least wish I'd gone for another brand! Moderator please advise
Moderator edit: format
03-02-2023
07:46
09:11
03-02-2023
07:46
09:11
Hi, it's good to see you around in the forums, @Lindarhasa.
Thanks for the details provided about this inconvenience you're experiencing with your Charge 5.
Before considering other options, please make sure that your device is properly set up with your Fitbit account. If your device is not set up, you will not see your daily activity and you won't be able to sync.
In addition, I recommend that you try restarting the device using the three pulse restart method:
If you're still having any issues to sync, let me know if you already tried all the steps listed here to resolve syncing problems, and make sure to check the compatibility requirements listed here and to keep the Fitbit app updated to the latest version available.
