02-12-2023 18:32
02-12-2023 18:32
02-12-2023 19:31
02-12-2023 19:31
here are the support contacts I've gleaned over the years on the forums.
when there is someone available, chat is an option. Phone or Twitter works well, too.
https://myhelp.fitbit.com/s/support?language=en_US
Support is limited by the number of representatives available at a given time and the hours of operation. Chat lines are open when they have live help.
USA: call (877) 623-4997
UK: call 0800 069 8505
INDIA: call 000 800 050 1057
IRELAND: call 01 691 7502 (country prefix: +353)
Other contact options:
USA: click
Canada: click for options
02-13-2023 02:07
02-13-2023 02:07
@MikeTheSpike wrote:
- Tightening the smaller wrist band and pushing it up higher on my arm so it would read heart rate when I'm sleeping left a huge gauge on my arm, underneath the metal casing of the unit.
- There's no good option to both get a tight enough read for sensors and leave my wrist undeformed.
You don't need to tighten it very much to get the pulse measurement.
I use Charge 5 by holding it in a comfortable position on my wrist and without tightening, and I still get the measurement of pulse, steps, sleep... without any problem. And I've been using it day and night for three months now.
02-13-2023 08:36
02-13-2023 08:36
Have you considered getting a different band? I have a smallish wrist and replaced the original Fitbit band with a metal one that has a magnetic clasp. This band allows me a lot more flexibility on how tight I wear my Charge 5. It was less than $20 for a pair of bands from Amazon and well worth the investment to be able to comfortably wear my Charge 5 for 24/7 use.
