03-21-2023 05:10
03-21-2023 05:10
Hello...
My fitbit Charge 5 suddenly stopped showing the number of days exercised on my android phone. I have logout of the app, restarted my phone and logged back in and the information is not there. Can someone help?
Best Answer03-21-2023 05:23 - edited 03-21-2023 05:25
Welcome to the Fitbit community, @Cindy9849!
You can edit tiles on the Today page in your Fitbit app. Just tap on Edit in the upper right corner, then scroll down to find tile(s) you want to add to your Today page. Select any of these by tapping the plus sign on the right and finally tap on Done in the upper right corner.
You can also rearrange tiles to your liking when in edit mode.
Best Answer03-21-2023 05:29
03-21-2023 05:29
I think you should try resetting your device and restart it again.
Best Answer03-22-2023 04:56
03-22-2023 04:56
Thank you! This was the answer I was looking for.
03-22-2023 04:56
I had already tried that.
Best Answer03-22-2023 06:48
03-22-2023 06:48
You're welcome, @Cindy9849, thanks for your positive feedback!
If you have any further questions, do not hesitate to come back.
Best Answer06-30-2023 14:50
06-30-2023 14:50
Until June 27th 2023 I showed 677 consecutive days then it disappeared. In the past when This happened before I’d either close the app or log out and the tile would reappear. When I spoke with a rep previously they were helpful too have it show again. There is no tile on the app to add back on the bottom of the edit. So hopefully there’ll be a fix
Best Answer06-30-2023 15:05
06-30-2023 15:05
There are only 3 tiles on edit at the bottom of page, menstrual health, blood glucose and food!! Nothing for consecutive days
