08-13-2023 07:32
08-13-2023 07:32
I feel frustrated that recently the battery of my Charge5 easily drained in just less than a couple of hours since it was bought last Jan 2022 only. Any replacement for this item?
08-13-2023 10:19
08-13-2023 10:19
Hello @jennifer123456
Here are a couple of troubleshooting steps to try.
When my Charge 5 started rapidly losing power, I restarted and recharged my device multiple times over several days. This finally got my Charge 5 "unstuck" and the battery went back to lasting 6-7 days.
A couple of users found that turning off Sp02 helped reduce battery drain. One of the users also un-installed ECG & EDA which further helped reduce battery drain.
Lastly, this page has suggestions to improve battery life (tips are about half way down the page): Tips to extend Fitbit battery You might want to check to see if something was inadvertently switched on that is now causing your battery to drain faster.
08-26-2023 03:05
08-26-2023 03:05
Hi, thanks for your reply and I took your advice, but it's been 2 weeks now my charge 5 won't get back 😞
