09-20-2022
12:45
10:01
DavideFitbit
09-20-2022
12:45
10:01
DavideFitbit
Plugged into wall and watch says “check charger, battery is not charging” . Tried to plug unplug, different plugs, nothing. What’s up?
06:30
15:55
09-23-2022
06:30
15:55
Welcome back to the Community forums, @Zitter.
Thank you for the information provided regarding your Charge 5 that is not charging properly.
If this is related to the battery, please make sure that you've followed all the other steps provided in this article. If the device is charging, but the screen is completely black, make sure that you've also completed the three pulse restart procedure described here.
Hope this helps, I'll be around.
10-13-2022
10:01
15:55
10-13-2022
10:01
15:55
@charleskn Thanks for sharing your experience with this!
See you around. 😁
