12-17-2023
18:15
04:30
CrisVillaFitbit
12-17-2023
18:15
04:30
CrisVillaFitbit
12-19-2023 04:33
12-19-2023 04:33
Hi, @abc1392781 Welcome to the community forums.
I understand this situation and thanks for explaining to the challenges you've encountered in regards to the clock and alarm of your Charge 5.
I was able to confirm you contacted support as you mentioned and they were able to provide you with a solution, if you have any other questions or concerns about that, my best recommendation would be to contact them once again.
Thanks for your efforts and understanding!
Best Answer12-23-2023 14:37 - edited 12-23-2023 15:15
@CrisVillaFitbit Thanks for your reply. Yes, I contacted support. The solution they provided was a 50% discount code as I mentioned in my original message. The problem is that the discount code is not useful at all. The Charge 5 is no longer available on fitbit.com and has been replaced by the Charge 6. And Charge 6 is excluded from the discount code. So I am not able to purchase a replacement or upgrade of the defective Charge 5 that went bad right after passing the warranty period.
