I am unable to find the purpose or use of the vertical stack of colored bars on the left side of the Charge 5 Tracker Clock display. At times mine are all gray (dimmed). Other times I have only 2 or 3 of the bottom bars lite. They have never all been illuminated like the pictures show. There is nothing in the online User Manual, nor in the documentation supplied with the tracker that indicates what these bars mean.
Best AnswerHello @JDukes1
I’m guessing you’re using the same clock face as on the box. The lines at the side represent your progress towards that goal for the day. If you tap the bottom of the screen, the type of stat displayed will change.
If you don’t like it or are curious about what other Clock faces there are, please check them out (yours is called Comtinuum).
From the Today screen in the App on your phone, tap your profile picture then Charge 5. Then tap Gallery, then Clocks. You’ll be able to see all of the choices available. If you tap on them they should give screenshots and more information.
If you want to change yours, tap to install a new one and follow the instructions about syncing and so on.
I hope that helps a bit.
Best AnswerI just googled it to see what those were too. I just got the Fitbit charge 5 yesterday. And I do love it. It's nice knowing that I can change that. I did look at different screen faces for it but most of them you had to pay for.
Best Answer@yardwalker Fitbit makes all the Charge 5 clock faces and they are all free.
Laurie | Maryland
Best AnswerHi and welcome @yardwalker
As @LZeeW mentioned, the clock faces are free and available from the Gallery in the Fitbit app. Click here for instructions for: How to change Charge 5 clock faces
