05-16-2022 12:59
05-16-2022 12:59
A month or so ago I upgraded from a Charge 4 to a Charge 5 and since then I've noticed a significant increase in "Couldn't Sync your Charge 5" messages when I open the Fitbit App. This is easily fixed by performing a manual sync. Any thoughts on what could be causing this?
Best Answer05-17-2022 05:14
05-17-2022 05:14
@SunsetRunner wrote:Hello @EtheP
The issue your describing is quite normal for me as well. Fitbit App used to have a function call all day sync but has since done away with it. I’m under the impression that the all day sync was possibly removed to help stop battery drain. Either way since the all day sync was removed I find myself having to manually sync much more then I did in the past like yourself.
😃Hopefully that answers your question. Please let me know
Thanks MegaBite! Fitbit has gone back and forth on auto/automatic sync I can't keep track!!
Best Answer05-16-2022 17:05
05-16-2022 17:05
Hello @EtheP
😃 Hopefully that answers your question. Please let me know
05-16-2022 18:41
05-16-2022 18:41
I cannot sync as the app just shuts down as soon as I open it. This started this afternoon and four calls to support have gotten me no help. Any ideas?
05-16-2022 18:44
05-16-2022 18:44
I'm having the same problem my last sync was yesterday @11:00 p.m.
Best Answer05-16-2022 19:09
05-16-2022 19:59
05-16-2022 19:59
05-17-2022 04:45
05-17-2022 04:45
I am having the same problem everyday, and today my Fitbit just stopped tracking my steps. I have tried every suggestion to fix this problem and nothing has worked.
05-17-2022 05:14
05-17-2022 05:14
06:14
08:33
EstuardoFitbit
05-17-2022
06:14
08:33
EstuardoFitbit
Hello @For_Me , @MaryBS and @Miki916
Your issue is different then what the original poster @EtheP is addressing. The original post is about having to manually sync your Fitbit Tracker to the Fitbit App sometimes throughout the day but does indeed sync. Not syncing at all is an entirely different issue. The original poster has an answer now to their question.
I agree @EtheP ! I personally preferred the all day sync feature! I’d rather risk charging my Fitbit a tad bit more then to have to constantly be manually refreshing most of the time.
To address your issue I’d recommend trying to restart your Fitbit Tracker. Look here to see how it’s properly done: https://help.fitbit.com/articles/en_US/Help_article/1186.htm Also check here to insure your mobile device is compatible:https://www.fitbit.com/global/us/technology/compatible-devices
😉Hopefully restarting will fix your issue
05-17-2022 06:23
05-17-2022 06:23
@SunsetRunner wrote:Hello @For_Me , @MaryBS and @Miki916
That is correct. Mine will manually sync just fine, except throughout the day I will receive a message in the app that it couldn't sync (I see this as soon as I open the Fitbit app). A simple manual sync will fix that. The problem is I've noticed a significant increase in this issue once I moved from the Charge 5.
06-23-2022 11:07
06-23-2022 11:07
Fitbit Charge 5 does not syncing with my laptop running Windows 10.
It worked with Fitbit Charge 3.
Best Answer06-23-2022 11:38
06-23-2022 11:38
Unfortunately @ManfredJohann there are no more updates to the Fitbit App for computers and Fitbit has been transitioning away from computers for sometime now and focused on tablets and mobile devices. That’s most likely the reason your having issues with syncing. If possible I’d download the app on either a tablet or mobile device if you have one. Look here for more information: https://www.fitbit.com/global/us/technology/compatible-devices
