11-22-2021 13:34
11-22-2021 13:34
Hi there, I've found out that I am unable to customise the Charge 4 and remove the water intake and weight goal icons on my watch display. I'm just going to send it back and upgrade to the 5. I would like to know if the Charge 5 suffers the same issue? Can you actually move the water and weight icons from the watch face when you swipe up? Thanks.
11-22-2021 14:04
11-22-2021 14:04
Hello @Rossorosso
Yes you can remove them. You can just remove the tiles from the Today screen in the App on your phone and that should remove them from your tracker too. I don't use the water one at all. I do use the Weight one on the App but it doesn't show up on my tracker at all.
I don't know if it's strictly related to the Clock Face you choose or not, but when I swipe up, I can see Hourly Activity (250 steps), Heart Rate, Resting, Sleep, Sleep Score, SpO2 and Exercise (number of days).
I hope that helps a bit.
11-23-2021 09:13
11-23-2021 09:13
Water intake and weight goal do not show up on the tracker screen for the Charge 5. I have both tiles on my Today screen in the app.
@Wibby I think the clock face only influences what you see for the main/home display. I have tried a few different ones, and in each case the items I see when swiping up or down remain the same. I see the same tiles you mentioned, except for the Hourly Activity, which I assume doesn't show up because I have Reminders to Move set to Off.
11-23-2021 09:55 - edited 11-23-2021 09:56
I have the Charge 5 for a week now and haven't come across the water nor the weight icon om my tracker. This even while I do use the tiles in the app.
For me it would actually be a good feature to be able to add the amount of water directly to the tracker instead of via the app. So, maybe I'm missing something, but as far as I know, weight and water are not on the charge 5 tracker itself.
