05-20-2023
11:03
12:21
05-20-2023
11:03
12:21
Is there a way to be notified of leaving the Fat Burn zone? It would be great to have this prompt to up the pace to get back into the zone, particularly during the Walk exercise mode!
Best Answer05-27-2023 10:31
05-27-2023 10:31
It sounds like you are using the Exercise App. If so, try this:
After choosing Walk in Exercise App, on the screen that says 'Start' with the triangular arrow, note the little up arrow at bottom of screen; swipe up from that arrow to see settings that apply only to Walk; one of them will be Settings:heart zone notifications - turn that on. that will cause vibration every time you switch heart zones. I forget if it tells which zones you are moving to or from.
Actually I just verified this for Run choice but i think it is there the same for Walk also.
Best Answer05-28-2023 07:49
05-28-2023 07:49
Hi & welcome @LexiPawz
As JohnnyRow mentioned, if you are using the Exercise mode to track your Walk/workout, you will get a notification vibration when your heart rate moves between the 3 Active Zones. However, I don't think there's currently a way to get a notification if your heart rate drops below the Fat Burn zone.
