ECG Format unreadable in Word
ANSWERED
I successfully took an ECG reading and exported it via email to my computer.
However, it is in a format that cannot be converted by Word into readable format, it looks something similar to Wingdings.
What format do I need to change it to, or do I need to make an adjustment in Fitbit?
1 BEST ANSWER
Accepted Solutions
Ah, sorry about that @mushydom.
Here’s the thread I was getting the information from.  It might be worth trying some of the steps advised there.  ECG isn’t available in my country yet so I can’t check it out for myself.
Unable to download report
Good luck!
3 REPLIES 3
Hello @mushydom
If you go back to the report in your App, tap Export PDF.  That form should be readable anywhere.
 I hope that helps a bit.
No sorry that's what I have tried, I am digging into my settings on the App, Samsung Phone, and computer.
Good luck!
