Hello,
i experienced the black screen battery issue yesterday.
After having performed a reset of the charge5 and new install of the fitbit iOS app, everything seems to be back on track now… except the ECG which is not working anymore.
Do you guys have the same issue ?
Best Regards
Sam
Best AnswerHi @Samuelb61
The ECG app might not be installed. To double check:
You might try uninstalling & re-installing the ECG app, then restarting your Charge 5 to see if that will get it back working. If it doesn't work the first time, it might take a few times to work.
