ECG won’t sense finger tips on Charge 5
ANSWERED
Charge 5 ECG app will not sense my finger tips and continues to stuck on the prompt screen. The EDA scan however works fine with just a soft touch on both sides of the metal bars. Tried uninstalling the ECG app and device restart, still doesn’t help. Any ideas?
1 BEST ANSWER
Accepted Solutions
@SunsetRunner
Try moistening your fingertips before taking a reading to see if it helps, moisture conducts better.
Gary D.| Feeding Hills, MA MBG PE
Charge HR, Charge 2, Charge 3, Inspire 2, Charge 4, Charge 5, Pixel Watch 2, Pixel Watch 3
3 REPLIES 3
Hello @SunsetRunner and welcome to the Community.  I have a few thoughts.
  • In theory, calluses can affect readings.  Try using your thumb and a different finger than your index finger.
  • Have someone else try on their wrist.  If it doesn't work on someone else, then you probably have a defective device.  Contact Support
Laurie | Maryland
@SunsetRunner
This simple trick seems to solve the problem. Thanks for the tip
