10-06-2021 20:12 - last edited on 10-07-2021 07:31 by LiliyaFitbit
Most of the time I get this message and the picture of where to place fingers . I've updated the Fitbit, and tried it off and on my wrist. It rarely works but most of the time the above scenario occurs. Very frustrating. Any suggestions?
04-07-2022 11:13
04-07-2022 11:13
Thank you for sharing your experience with this as well, @lynette607.
04-07-2022 11:24
04-07-2022 11:24
This solution does not work with mine and it did not work with the first one. Someone at that time suggested wetting the fingers and it works about 90% of the time. I seldom reads the heat rate in doing the procedure BUT if you look at the heart rate indicator, it is reading the heart rate. It appears to me that sensors and/or the app is still not working. 4/7/22
04-07-2022 12:19
04-07-2022 12:19
04-07-2022 13:06
04-07-2022 13:06
Me too, was annoying me 😂
04-15-2022
10:02
13:10
04-15-2022
10:02
13:10
@CTOCS I appreciate the information that you've shared and for confirming that you already tried the recommendations mentioned earlier.
Keep in mind that if you're constantly experiencing this problem after all the troubleshooting steps suggested in the thread, I recommend that you get in touch with the Customer Support team so they can let you know how to proceed. Click here to get connected.
@Button19 @lynette607 Thank you for sharing these updates!
See you around.
04-15-2022 17:27
04-15-2022 17:27
04-16-2022 00:19
04-16-2022 00:19
Just tried again. Only works if I wet my fingers before touching the sides. Fitbit there's obviously something not right as too many people experiencing issues. Does it need you to wet fingers first? Could this be a design error for this particular function
04-22-2022
06:07
13:11
04-22-2022
06:07
13:11
@CTOCS @lynette607 I'm sorry to see you're still experiencing this problem with your Charge 5. Thank you for all your feedback about this.
Not all users are experiencing this behavior. For the moment, it's recommended to get in touch with the Customer Support team if you continue to experience the same problem after the restart procedure. They will let you know how to proceed.
See you around.
04-28-2022 11:37
04-28-2022 11:37
This worked for me too! Thanks!
05-04-2022 10:05
05-05-2022 09:09
05-05-2022 09:09
I had exactly the same issue (new user, just getting used to the device). I think for me, my fingers were just too dry. I tried breathing on them and with a small increase in moisture, it worked fine.
05-07-2022
09:50
13:11
05-07-2022
09:50
13:11
Welcome to the Community forums, @Ianknowles12.
That's a helpful tip, thanks for sharing your experience with this. 😁
05-10-2022
16:04
09:41
DavideFitbit
05-10-2022
16:04
09:41
DavideFitbit
Brand new charge 5 is doing the same thing come on Fitbit fix it
Having same problem snd getting same erro
05-10-2022 16:52
05-10-2022 16:52
tt appears that FitBit is not going to fix the problem and we will have to continue licking or fingers to get it to work. 😞
05-11-2022 02:14
05-11-2022 02:14
At least it works that way, I'm glad found the previous post as licking fingers works everytime. Just have to sit still for few mins🤣
05-13-2022
09:40
13:11
05-13-2022
09:40
13:11
@Sdumond @CTOCS @lynette607 Thank you for all the updates and feedback that you've shared. This is a workaround that some users have shared and that it's helpful in the meantime.
However, if you already all the recommendations listed here earlier and the three pulse restart procedure and you continue to have any problem to complete your EDA sessions, I do recommend that you continue the assistance process with the Customer Support team so they can provide you with the next steps. You can click here to get connected
Thanks again for the information provided; our team is always working to enhance your experience and your feedback is a big part of that process.
05-18-2022 17:31
05-18-2022 17:31
Recently I posted Eda not working pausing on finger position I went into settings and did a restart and everything is working properly
05-20-2022 07:56
06-24-2022 10:41
06-24-2022 10:41
That's it! I had the problem with EDA not working, read this comment, licked my fingers, and problem solved!
06-24-2022 13:27
