01-30-2023 09:58
01-30-2023 09:58
Try to use the EKG scanning but only get the message that something is wrong and I shall try later. I have got the same messade a couple of days now. No problem earlier.
		03:16
		10:45
		01-31-2023
		03:16
		10:45
@Gunlli Welcome to the Fitbit community!
Sad to hear that your Charge 5 isn't working properly. I'd suggest restarting your device as a first step. To do so, please follow these instructions:
1.) Connect your device to the charging cable which has to be connected to a power source.
2.) Press the button located on the USB plug of the charger 3 times within 8 seconds, holding each press for about 1 second(!).
3.) Wait 10 seconds or until the Fitbit logo appears.
Also be aware that the finger tips you use for taking an ECG shouldn't be totally dry as a little bit of moist is needed for electric conductivity.
		03:16
		10:45
		01-31-2023
		03:16
		10:45
 Best Answer01-31-2023 11:12
01-31-2023 11:12
 Best Answer01-31-2023 11:52
                              01-31-2023 11:52
@Gunlli You're welcome, thanks for your feedback!
