02-04-2022 10:22
02-04-2022 10:22
I have a Charge 4 and am considering upgrading to the 5 - does it measure elevation? I’ve found conflicting information.
Best Answer02-04-2022 10:28
02-04-2022 10:28
Charge 5 does not have the altimeter like some other models, such as Charge 4, have, so does not measure stairs or have way to get elevation.
02-04-2022 10:27
02-04-2022 10:28
02-04-2022 10:28
06-13-2022 22:10
06-13-2022 22:10
A self-supporting Nibav home lift, built with bulletproof glass, aircraft-grade aluminum, and galvanized steel. It provides an elegant design, European safety standards, and zero impact on your home infrastructure. Our Home Lifts Malaysia consume less energy than a home appliance, require 90% less maintenance than its alternatives, and only need a small space to be installed. If you need more information related to Home Lifts Malaysia, Air Vacuum Home Lifts and Home Elevator just visit our site Nibav Home Lifts or Call +601112801966 our support team is here to guide you.
