11-11-2021 00:47
11-11-2021 00:47
Im using my suunto heart rate chest strap and on walk it gave me 260 cals and charge 5 gave me 90 cals
On my crossfit suunto gave me almost 600 cals and Charge 5 gave me 130 cals.
What is happening why the cals are so low on my charge 5
Best Answer11-11-2021 08:59 - edited 11-11-2021 09:00
2 possibilities I can think of right off to check:
1) Check your weight in Fitbit; if it entered way too low, that gives lower calorie burn. Could be a decimal point off or wrong units.
2) If you are relying on exercise auto-recognition, check in your exercise summary that the whole workout time was recorded. If you used the Exercise App, that shouldn't be an issue because you tell it when you start and end.
Best Answer11-13-2021 06:16
11-13-2021 06:16
Thank you @JohnnyRow my weight was 7kg so that might bee the reason, im not that tiny. XD
Cant stop laughing!!
