10-13-2022 03:09
10-13-2022 03:09
We will appreciate some elaboration regarding some data in the API and Archive:
Thanks !!
| API | Question | Answer |
1. | Get Heart Rate Time Series by Date
| Seems like the API does not provide the “Activity types” (running, walking, etc.) where can we find it? |
2. | Where can we find the “resting heart rate” as a “stand-alone feature”? Currently, it appears per activity, at the current API but, if we do not track the Activities? |
3. | ?? | “Heart rate - beats per minute” - in which API it appears? |
4. | Get Sleep Log by Date \ Get Sleep Log by Date Range
| Table User_sleepdata à“Sleep: efficiency” - how it is calculated? Any documentation? |
5. | Table User_sleepdata à “sleep: "info code” – where we can find code documentation? |
6. | Why are the sort sleep periods (“wake” only?) presented in a different table (users_sleeplevelsshortdata ) while the users_sleeplevelsdata includes actually the full sequential data of sleep stages? |
7. | In the Fitbit application, we see both: classic levels (restless | asleep | awake) and stages (deep | light | rem | wake).
But in the 1.2 API we have only by stages (deep | light | rem | wake) – is that correct |
Archive data | Question | Answer | |
1. | mindfulness_eda_data_sessions | “activation” – stands for? |
2. | mindfulness_sessions | “stress_metrics” - where can we see the data which is calculated according to these metrics? Else how it is being used? |
3. | Estimated oxygen variation | What considers to be low? Or high? |
4. | Heart Rate Variability | Any documentation regarding: Coverage? low_frequency? high_frequency? |
| Stress score | Any elaboration regarding. It is not very clear from the documentation: § SLEEP_POINTS § MAX_SLEEP_POINTS § RESPONSIVENESS_POINTS § MAX_RESPONSIVENESS_POINTS § EXERTION_POINTS § MAX_EXERTION_POINTS |
| Computed Temperature | “baseline_relative_sample_sum” – we see negative values – what do they represent? |
| VO2 Max | Any documentation regarding: § demographic_vo2_error? § filtered_demographic_vo2max? § filtered_demographic_vo2max_error? |
Best Answer10-13-2022 14:26
10-13-2022 14:26
I'd suggest posting this is one of the appropriate developer forums.
CharlesKn | Mid-Atlantic, USA
60+, strength and cardio
Charge 5, Android, Windows
