11-30-2022
15:15
06:21
DavideFitbit
11-30-2022
15:15
06:21
DavideFitbit
My Fitbit Charge 5 is overcounting the number of lenghts i do while swimming in the pool. I did 16 lenghts today and it counted as if i did 26 lenghts... What can be causing this problem?
Moderator edit: format
06:20
06:19
12-07-2022
06:20
06:19
Hi, welcome to the Community forums, @JoseScocci.
Thank you for the information provided about what you've been experiencing with your Charge 5.
There are a few reasons that can usually cause inconsistencies with your swim data:
In addition to the reasons mentioned earlier, and if you already checked the pool length is accurate in the Fitbit app, please try to complete a restart procedure using the charging cable and check if you continue to experience the same behavior:
Hope this helps, I'll be around.
