08-15-2023
09:01
10:11
08-15-2023
09:01
10:11
Find phone foes kot show on Fitbit screen
Best Answer08-15-2023 11:05 - edited 08-15-2023 11:06
Hello & welcome @Mooreorless
The first thing that I suggest is to confirm that Find My Phone has been installed for your Charge 5. To do this:
If you see that the Find My Phone app is installed, then tap Uninstall to remove the app, sync your Fitbit app & Charge 5. Then, go back, re-install the app, and sync the app & your Charge 5.
Hopefully, you will only need to do this once to be successful.
Best Answer08-15-2023 12:00
08-15-2023 12:00
Best Answer08-15-2023 12:45
08-15-2023 12:45
Hi @Mooreorless
Yay! Thanks for letting us know that you got it figured out and everything is good now.
Have fun with your Charge 5.
PS: I'm still learning about my Charge 5 and I've had it for a year.
