01-31-2024
05:40
07:03
01-31-2024
05:40
07:03
My Fitbit 5 only 6 months old is totally unusable now after December update. I thought only mine was bad but now I see it’s happening to tons of users. Company needs to replace with the 6 to all of us with the issue.
02-20-2024 20:39
02-20-2024 20:39
Same here i got mine only 7 months
Best Answer02-21-2024 11:39
02-21-2024 11:39
Hello @Briscoe2104 & @Nissuoat
Since you've tried the recommended troubleshooting steps without success & your devices are less than a year old, you should contact Fitbit support (<-- click link) to see what options you have under warranty.
Best Answer02-22-2024 05:32
02-22-2024 05:32
Wow that's really bad and I appreciate your sharing your experiences. I've had mine for about 2 years and other than initial setup and battery draining problems, I've never had an issue with software updates or getting it wet. I even went in a pool and a lazy river water kind of thing a couple of times. Sorry you've been having problems with yours, probably a quality issue in manufacturing.
