01-27-2022
18:44
13:09
DavideFitbit
01-27-2022
18:44
13:09
DavideFitbit
This is a brand new Fitbit Charge 5. The heart rate is higher by 15 to 20 points constantly. I check it against my Samsung Smart watch and the Omrion blood pressure instrument. Both Samsung and Omron are almost the same +/- 2 point.
Was very surprised thar Fitbit cannot get it right after so many comment since Fitbit Charge 4. May want to return it and go back to my Samsung.
Can you fix it?
01-29-2022
13:08
09:24
01-29-2022
13:08
09:24
Hi, welcome to the Fitbit Community forums, @TTLAY.
Thank you for sharing this information about the inconvenience you've been experiencing with your Charge 5.
If you haven't done so already, I recommend that you try restarting the device using the three pulse restart method mentioned here below, instead of the restart option found on the Charge 5 itself:
In addition, please follow the instructions in this article to improve the accuracy of heart rate information and check the information mentioned here about other factors that could affect your heart rate reading, this has been useful to other users who have experienced something similar.
Hope this helps, I'll be around.
01-31-2022 19:12
01-31-2022 19:12
Best Answer01-31-2022 19:18
01-31-2022 19:20
01-31-2022 19:20
05:38
09:24
02-01-2022
05:38
09:24
02-05-2022 20:24
02-05-2022 20:24
02-12-2022
17:39
09:24
02-12-2022
17:39
09:24
@TTLAY Thank you for confirming that you already tried all the troubleshooting steps suggested earlier.
In this case, since you already tried all the steps shared in the forums and you continue to experience the same problem with the heart rate, I recommend that you get in touch with the Customer Support team for further assistance with this. They will let you know how to proceed.
The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
See you around.
11-01-2022 08:33
11-01-2022 08:33
Im going to try this when I get home, but I just bought one a few days ago. Ive had fitbit for yeaaars, with accurate HR, no problems. This one seems to be way too high at all times. It even shows my resting heart rate higher whether at rest or exercise. The back of it is clean
Best Answer11-01-2022 09:19
11-01-2022 09:19
I don't think it does read high or my real resting heart rate would be 30
06:00
09:24
11-23-2022
06:00
09:24
Hi, it's good to see you visiting the Community forums, @mckenna1217 @SunsetRunner.
Let me know if you continue to experience any difficulty after trying the steps suggested earlier to improve heart rate accuracy in general.
I'll be around in the Community.
