Fitbit Charge 5 freezes during gps workout, stopt recording!
Since the last update (I have only had 2 updates since I purchased it, which is very poor considering the amount of bugs this device has), my Fitbit Charge 5 freezes almost everytime during a gps tracked workout. It seems to happen especially often when, during the run, I reach my daily stepcount. This is massively frustrating because it also just spontaneously stops recording the run. Very discouraging and very poor for a watch who's key feature is GPS for exercises. Also very dissapointed in my first, and quite expensive, Fitbit watch. I'd rather use my old cheapass samsung galaxy fit 2 right now considering the massive amount of bugs in the charge 5...
Hope Fitbit will come with a proper update for this very soon. This has also been my first and last Fitbit watch, will go with brands such as Garmin in the future. Does anyone encounters the same problem?
Moderator edit: format
1 REPLY 1
Hi, welcome to the Fitbit Community forums, @Lararozo
Thank you for all the information provided about the problem you've been experiencing with the Charge 5.
Before considering other options, make sure to follow the steps suggested in this article to improve accuracy of the GPS.
All devices with GPS sensors require a direct path to GPS satellites to calculate location. A weak GPS signal might affect the accuracy of your route and other activity data. Your device uses your step count to calculate distance until it finds a signal, so the total distance calculated for a workout may be slightly less accurate when GPS isn't available for the entire time. In particular, please make sure of the following:
  • That you are  in open sky and moderate trees
  • Adjust how you wear the tracker when you want to use GPS
  • Make sure the Location in your phone settings is set to Always or All the time for the Fitbit app (if you're using connected GPS)
If you continue to experience the same behavior and your GPS is getting disconnected, make sure to try following the steps listed here below to complete a restart:
  1. Connect your device to the charging cable. For instructions, see How do I charge my Fitbit device?
  2. Press the button located on the flat end of the charger 3 times, pausing for 1 second between presses. Then wait 10 seconds or until the Fitbit logo appears.
Thank you for taking the time to share all your feedback about the product as well.
I'll be around.
