05-18-2022
20:32
07:13
AndreaFitbit
05-18-2022
20:32
07:13
AndreaFitbit
My fitbit 5 has stopped showing my heart rate for about 2 days it is new as in 1 month old. I have cleaned it taken it off etc but nothing worked
Moderator edit: format.
05-18-2022 20:36
05-19-2022 02:41
05-19-2022 02:41
Checked all that and everything seems OK
05-19-2022 09:48
05-19-2022 09:48
Hi, @Paulrc , in that case I would recommend turning off heart rate on your device, waiting a moment, and then turning it back on again. That might help.
05-19-2022 11:00
05-19-2022 11:00
This happened to me yesterday too…it also syncs to my phone but doesn’t come up with any stats. Weird. No answer yet.
05-19-2022 11:22
05-19-2022 11:22
I have got it going again I pressed the reset button on the watch and it seem to of solved it
05-19-2022 19:23
05-19-2022 19:23
The heart rate is no longer accurate anyway. My Heart rate dropped by anywhere from 5 to 10 BPM since "Upgrading" to Charge5.
05-20-2022 11:30
05-20-2022 11:30
How long has it been recording your heart rate now? I reset mine and it lasted only one day and it doesn't record my sleep patterns either.
05-21-2022 08:47
05-21-2022 08:47
05-21-2022 09:20
05-21-2022 09:20
05-22-2022
06:18
07:02
DavideFitbit
05-22-2022
06:18
07:02
DavideFitbit
I am also having the same problem and the red light is constantly on now and it wears down the battery until it goes dead. I've only had it less the 5 months!!
I've reset the app, updated the Fitbit, turned heart rate on and off.....nothing is helping
05-22-2022 06:52
05-22-2022 06:52
05-27-2022 21:13
05-27-2022 21:13
I agree, I came on here to see if there was an update. My heartbeat does not work, neither does my zone minutes. Fairly new Fitbit too.
05-28-2022 04:22
05-28-2022 04:22
Mine is doing the same. No sleep data - no heart rate bpm data. Bpm graph does record bit it is not informing any of the other health metrics. I have spoken twice to fitbit. Told to reset the fitbit, reconnect the fitbit, wear tighter at night. All to no avail! No data since 13th May! Very frustrated. As someone suggested - i dont believe it is my heart.
05-28-2022 04:35
05-28-2022 04:35
I did everything Fitbit suggested and nothing worked. I was told they would escalate it to another team and get back to me via email and never received an email from anyone at Fitbit. Luckily it was purchased from Amazon, and after telling them everything I did to try and fix it, they let me return it. Check to see what type of warranty Fitbit has, or if you can return it from where you purchased it. I was very disappointed with Fitbit for not even bothering to help me further. Hope this helps someone.
05-28-2022 04:50
05-28-2022 04:50
05-28-2022 14:08
05-28-2022 14:08
05-28-2022 16:30
05-28-2022 16:30
06-20-2023 07:02
06-20-2023 07:02
Hi everyone, thank you for sharing the some of you are still experiencing issues with heart rate and GPS.
It seems that most of you have already tried all the steps shared in the forums to try to resolve this problem.
I will go ahead and close this thread. If you're still experiencing any of these issues, please get in touch with the Customer Support team or make sure to continue the communication with them if you already have a case created, so they can provide you with the next steps.
If you are experiencing an issue with your Charge 5 unrelated to heart rate not working properly, I invite you to start a new topic on the community or find a related topic.
Thanks again for all your feedback and contributions on this thread.
