08-24-2022
06:30
07:27
DavideFitbit
08-24-2022
06:30
07:27
DavideFitbit
Fitbit Charge 5 won’t update and won’t sync
Moderator edit: format
07:26
16:17
08-25-2022
07:26
16:17
Welcome to the Fitbit Community forums, @Pfmhaynes.
I appreciate the details provided about this issue with your Charge 5.
Regarding the information about the device not updating, let me know if you're referring to the firmware update or if you mean that your device is not syncing and the information is not updating in the app.
In the meantime, I recommend that you try restarting the device using the three pulse restart method described here below:
Keep in mind that you need to sync through the Fitbit app and not through the Bluetooth settings on your phone. In addition to the restart, please make sure that you've tried all the steps listed here to resolve syncing problems, and make sure to check the compatibility requirements listed here and to keep the Fitbit app updated to the latest version available.
Hope this helps, I'll be around.
@Pfmhaynes Thank you for your reply.
Let me know if you continue to have the same problem after the troubleshooting steps suggested.
In the meantime, you can also find some useful recommendations in this article if you're having trouble to complete the firmware update.
I'll be around.
