04-28-2022
19:07
07:11
DavideFitbit
04-28-2022
19:07
07:11
DavideFitbit
This AM the Fitbit Charge 5 was 100% charged. I was exercising last night and it had recorded steps, active minutes etc after midnight.
The Fitbit was no longer counting steps this morning and I couldn't synch the Fitbit. I removed it and tried to set it up again, but nothing happened.
I see the time, the date and the charge.
Moderator edit: format
07:10
08:55
04-29-2022
07:10
08:55
Hi, thank you for sharing this information about the inconvenience you've been experiencing with your Charge 5 and that you already tried a few troubleshooting steps, @CarlsNY.
Before considering other options, I recommend that you try restarting the device again using the three pulse restart method mentioned here below, instead of the restart option found on the Charge 5 itself:
In addition, you can also try changing the clock face option on your device.
Hope this helps, I'll be around.
