10-06-2021 07:19
10-06-2021 07:19
It has been reported and discussed here previously:
When the always on display is dimmed, the stopwatch stops ticking. It is only when you wake the screen that the stopwatch catches up with itself.
I really am not sure why Fitbit sent me a replacement if this behaviour is standard?
https://imgur.com/a/dyzGosA
Best Answer10-06-2021 09:42
10-06-2021 09:42
Hi @SunsetRunner.
I agree that this sounds like normal behaviour. I believe in order to save battery life, the always on display has a refresh rate of once per minute. This is why it looks like the image is frozen until it refreshes (each minute).
It's strange the support sent you a replacement, perhaps there was a misunderstanding (their end) as to what the issue actually was.
