10-10-2022
07:49
07:47
DavideFitbit
10-10-2022
07:49
07:47
DavideFitbit
I am trying to connect my Charge 5 to my iPhone. It will not connect. I have turned off my Bluetooth and turned it back on and restarted my Fitbit, but it still will not connect even though it has found the Fitbit.
10-12-2022 07:47
10-12-2022 07:47
Hi, welcome back to the Community forums, @JBCur10.
I appreciate all the information that you've shared about the difficulty you're experiencing with your Charge 5.
If you haven't done so already, please try the following steps that have been useful for other users:
In addition, I recommend that you try restarting the device using the three pulse restart method:
If you're still having any issues, let me know if you already tried all the steps listed here to resolve syncing problems, and make sure to check the compatibility requirements listed here and to keep the Fitbit app updated to the latest version available.
Hope this helps, I'll be around.
