09-03-2022
07:53
11:05
DavideFitbit
09-03-2022
07:53
11:05
DavideFitbit
Hi I have a Charge 5 and 3 days ago I went for a run got back step count was 16,275 then looked again it had gone down to 13,166, not the first time this has happened! Also it records my workouts twice. Yesterday it froze I tried charging to 80% reset using charging lead and nothing after a couple of hours it just went dead. Put it back on charge and it came back to life. So was a day without the watch. Seems ok now. Anyone else had this issue?
Moderator edit: format
Best Answer09-20-2022 11:05
09-20-2022 11:05
Hi, thank you for sharing that you've having this inconvenience with your Charge 5 device and that you already tried a few troubleshooting steps, @JayneD43.
It's good to know that you're device is now turning on. Regarding this problem and the other issues you mentioned earlier, I recommend that you try restarting the device using the charging cable:
In addition, you can try setting up your Charge 5 as a new device in your account. Let me know if you continue to have any of these problems.
Hope this helps, I'll be around.
