07-13-2022
06:45
10:04
DavideFitbit
07-13-2022
06:45
10:04
DavideFitbit
Once again my charge five has stopped recording my heart rate variability. The last three nights it’s recorded as zero. It seems with Fitbit it works fine for a year and then after you’ve had it for a year everything starts to stop working. This will be the last one I get I’m not doing this every year.
07-13-2022
10:04
08:20
07-13-2022
10:04
08:20
Welcome to the Community Forums, @Bam2448.
Thank you sharing this information about the issue you've been experiencing with your Charge 5.
Before considering other options, please keep in mind the following to make sure you see your health metrics data:
For more detailed information, see What should I know about health metrics in the Fitbit app? In case the HRV is being tracked but it's not being shown in the app, please try the following steps as well:
In addition, please make sure to keep the Fitbit app updated to the latest version available.
Best Answer07-01-2023 11:15
07-01-2023 11:15
I also have experienced the same issue. I followed your recommendations with no results.
Best Answer07-30-2023 06:46 - edited 07-30-2023 06:46
@Metwo2 Thank you for your reply and for confirming you're experiencing the same problem.
If you have't done so already, I'd also recommend that you try setting up your Charge 5 as a new device in your account. Then check if you're able to see your information in the app.
