12-03-2021
19:12
05:36
DavideFitbit
12-03-2021
19:12
05:36
DavideFitbit
Hi. Lately my C5 has on occasion reported an abnormally high heart rate. I usually notice because I get an alert from the device that I've reached some Zone Minutes level, even though I'm not active at the time. It resets after I restart the device and then tracks accurately again. But I'm having to do this daily which is a pain.
Anyone else run into this and/or have a fix?
Thanks.
Best Answer12-07-2021 05:36
12-07-2021 05:36
Hello @Maxinelabutte, thank you for sharing this information about the inconvenience you've been experiencing with your Charge 5 and that you already tried the restart procedure many times.
Before considering other options, I recommend that you try restarting the device again using the three pulse restart method mentioned here below, instead of the restart option found on the Charge 5 itself:
In addition, please follow the instructions in this article to improve the accuracy of heart rate information and check the information mentioned here about other factors that could affect your heart rate reading, this has been useful to other users who have experienced something similar.
Hope this helps, I'll be around.
