12-10-2021
18:12
14:52
DavideFitbit
12-10-2021
18:12
14:52
DavideFitbit
Hi,
Heart rate stops working every few days. I have tried restarting using both ways. restarting through the watch itself and restarting through three clicks on the charger. after the restart, it works for a few days without a problem and then HR disappear. Fitbit is only two weeks old.
Best Answer12-11-2021 14:51
12-11-2021 14:51
Hi, welcome to the Fitbit Community forums, @NareshSathy.
Thank you for sharing this information about the problem you've been experiencing with your Charge 5 and for confirming that you already tried the restart procedure a few times.
In addition to the restart, please follow the instructions in this article to improve the accuracy of heart rate information and check the information mentioned here about other factors that could affect your heart rate reading, this has been useful to other users who have experienced something similar.
It seems that you had already contacted the Customer Support team about this problem. In this case, if you continue to experience the same problem after all the steps suggested, I recommend that you continue the communication with them so they can let you know how to proceed. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Hope this helps, I'll be around.
21:27
09:35
DavideFitbit
01-30-2023
21:27
09:35
DavideFitbit
I have a relatively new (few weeks old) charge 5 and I have the same problem. After restarting it, it will show the heart rate fine for a few days and then stop showing it (just dashes) until I restart. I updated the firmware relatively recently but don’t remember if it had the problem before the update, but it certainly does now. I see a few other people seem to have the same problem. Has it been reported enough that Fitbit is looking into it?
Moderator edit: format
09:58
08:50
02-09-2023
09:58
08:50
@TedL Thanks for confirming that you already tried the restart and that you've been experiencing the same issue with your Charge 5.
In addition to the three pulse restart procedure using the charging cable, please follow the instructions in this article to improve the accuracy of heart rate information and check the information mentioned here about other factors that could affect your heart rate reading.
If the issue persists, please try setting up your Charge 5 as a new device and check if you continue to have the same problem.
