Help me decide what color band should I choose for Charge 5?
Figured I could get some help 😜!
I can’t figure out which color Hook & Loop Band would go good with the Gold charge 5. I like the blue, but in my mind idk if they would clash…opinions?
7 REPLIES 7
Hi @SleepyxEquus  I just looked and to me, the blue would work perfectly. I don't think they would clash and I do try not to have mismatched items myself. Did a quick thing to see how it looked. It seems fine to me, but ultimately, it's what will be on your wrist. Let us know what you decide.
Stepping in the U.S.A. since September 2013. Android 14
@SleepyxEquus   I don't think they will clash.  I have some bathroom tiles that look close to the coastal blue band.  If the gold is the same gold as the Luxe, then I think it will be fine.  You can always wait a month or so.  There are no third party companies offering Charge 5 bands on Amazon, but there are hook and loop bands for other devices.  It might take that long for some to show up and there might be a better color selection.  The Charge 5 band has a different attachment style, so Charge 3/4 won't work.  I had very good luck with third party bands when I wore my Charge 2.
Laurie | Maryland
Thank you!! That looks great together! Definitely will get blue.
Sadly I break out in a nasty rash from the silicone bands the fitness devices come with. So I have to get one before the device gets here to use it. :(, sadly only one on Amazon right now is the sports band.
I got the gold and black leopard one and I got the beige one and they look awesome
That don't look good at all
 The beige one looks really good too
