09-07-2022 21:24
09-07-2022 21:24
I seem to recall there is a setting for that, but can't remember where it is and can't find it. My Charge 5 used to turn on when I moved my wrist but no longer does that. I've seen a number of similar questions in the Forums but no answers. Can anyone help? Thanks.
Best Answer09-08-2022 05:11
09-08-2022 05:11
Hi, @judyrace , this used to be on the app, but now is on the device itself. On your Charge 5 swipe down to access the quick settings menu (gear icon). Tap to open and then choose “display”. Swipe up to find “Screen wake” and make sure it is set to “auto”. You can also set “off hours” there so it doesn’t turn on in the night…
The movement to make it wake up is a slight lift of the wrist and quick flick. Sometimes it can take a while to get the hang of the movement so it consistently wakes.
I hope this helps!
09-08-2022 12:14
09-08-2022 12:14
