12-02-2021 07:23
12-02-2021 07:23
I want to add the ECG function but cannot figure out what I need to do? The instructions mention an app but I cannot find one.
Best Answer12-02-2021 13:51
12-02-2021 13:51
Hello @KelliSV
It might be worth checking if your country has approved the ECG App first. If you click on this link and scroll down to the bottom of the page, you can check to see if your country is there.
If it's available in your country but not showing up on your tracker or App, it might be a good idea to check for updates for both in case it turns up.
I hope that helps a bit.
12-02-2021 13:51
12-02-2021 13:51
Hello @KelliSV
06-28-2023 14:39
06-28-2023 14:39
Go to "Discover ",scroll down to "assessments & Reports" slide to "Irregular rhythm notifications" tell them you have never had A-Fib. hit nest, scroll down until the accent lights up.
