09-17-2024
04:25
08:32
LizzyFitbit
09-17-2024
04:25
08:32
LizzyFitbit
In the app (version 3 because 4 is offensively bad) I have set the exercises to:
1. walk
2. elliptical
3. weights
On my Fitbit Charge 5 the order is: Weights, elliptical, walk.
When I get to the gym I start _elliptical_.
When I stop _elliptical_ I want to start _weights_ but the order has changed to: elliptical, weights, walk.
How do you manage to make it so broken?
Best Answer09-17-2024 11:13
09-17-2024 11:13
Hello @rwb196884
I believe this is working as designed. Your most recent exercise will show first, followed by the next recent activity.
In the scenario you provided, I would expect the exercise order to show on your Charge 5 as Weights, Elliptical, Walk after you did Elliptical first, followed by Weights.
Best Answer09-17-2024 12:37
09-17-2024 12:37
@RiekoC Thank you for your help !
@rwb196884 , A warm welcome to the Community! Thank you for your message and info.
Just jumped in to add to RiekoC 's info.
As mentioned, you'll see the 3 most used activities on the top . If you scroll down, you'll see the "more " button. By pressing it, you'll see the rest of the available activities to be elected. The 3 most used could change depending on how often you select an activity.
