05-19-2023
08:38
10:27
05-19-2023
08:38
10:27
I lost my charge 5 Fitbit last night and haven’t been able to figure out how to track it right. The gps I believe is turned on but there is no “track my Fitbit” feature in the Fitbit app…and I don’t want to pay for an app to find it. Any suggestions? Thanks!
05-19-2023 09:13
05-19-2023 09:13
Hi, @Chfin , there is no track my Fitbit app. However, if you go to the places where you think you might have lost your Fitbit you can open your app and try to sync it. If it syncs, you know it is nearby! That happened to me once - I lost mine Christmas shopping one year and I had been to lots of stores. I went to each of them and opened the app. No luck until the very last stop - I went in and it synced immediately. The store manager said it hadn’t been handed in and wasn’t there, but I knew it was… The security guard found it for me stuck to the bottom of one of the shopping carts.
Of course this only works if the Fitbit has batteries.
You can also use a Bluetooth finder app, but you usually have to pay a small charge for these - a lot cheaper than a new Fitbit, however! It is important to find it while it still has battery, however. Another good reason for keeping your Fitbit charged up.
Good luck! Let us know if it turns up. Welcome to the forums.
