11-02-2021
14:59
15:42
LizzyFitbit
11-02-2021
14:59
15:42
LizzyFitbit
Hi,
How do I sync fitbit charge on PC, as my iphone 6 not compatible, and not buying new phone just to sync.
Thx
Best AnswerHello @lindalsj22 ,
Here's a link to syncing information:
You have to scroll down a bit to find the type of computer you have.
Hopefully if you click on the links there, it should help.
Good luck!
Best AnswerHi,
Thanks for getting back to me I have it on my PC Bluetooth enabled just won't sync...I will try your link and let you know..
Thx
Best Answer@lindalsj22 I responded to your similar post in the iOS forum. To clarify things, you cannot setup a Charge 5 on a computer, PC or Mac. An iPhone must support iOS 13 or newer. An Android phone must support Android 8 or newer.
Repeating what I wrote in my other post, you should definitely consider replacing your phone. Apple stopped supporting the iPhone 6/6+. You do not get security updates. Apple released an important security update that you did not and cannot get.
Laurie | Maryland
Best Answer@LZeeWIt's not correct to say Apple is not providing security updates for the iPhone 6 and 6+. They have said repeatedly that they will continue to provide those updates for the 6 and 6+. The last one rolled out in December. I have a 6+ and have continued to get those updates. Your glib comments about "it's time for a new phone" are not helpful. https://support.apple.com/en-us/HT201222
