11-26-2022 15:19
11-26-2022 15:19
I have a new Charge 5 and like to keep the older ( still working) Charge 3 active. It appears I can not have 2 fitbit charge on the account ( I must delete the Charge 3). What are my options? Can I set up a second account on my Android Phone and just switch between them? I understand the daily usage info will be not accumulated if I switch during the day?
Best Answer11-26-2022 15:30
11-26-2022 15:30
Hi @retiredpd you can't have both on the same account and you can't combine stats from two different accounts. click to learn more. What you can do is switch devices each time you want to wear the other Fitbit. Set up the one you want to use, get active and then sync. Set up the other one, same thing. You can only keep the history going on the one account.
