03-29-2022 11:27 - edited 03-31-2022 08:46
I have exercise activities that need edited/cropped shorter as I forgot to stop at actual end of activity. The android app let's me view the exercise and shows 3 dots that only gives options to export the file or delete the activity. No where to edit. No pencil icon to click.
03-29-2022 12:31
03-29-2022 12:31
Hello @Mirvin246
Where have you been trying to edit them? It should be possible to do it from the App on your phone.
If you tap on the exercise record you want to edit, then the 3 dots at the top right of the screen (on an iPhone) you get the options to Edit Exercise Details, Delete or Cancel. If you tap on Edit Exercise Details, you should get the option to change the times.
If you’re using Android, I think you get a pencil instead of the 3 dots.
I just checked the Dashboard at Fitbit.com and that only gives the options you list. Try from the App on your phone and you should hopefully be able to edit them there.
I hope that helps a bit.
