How to get rid of the batteries and of your Fitbit?
how to get rid of the batteries and off your Fitbit
Moderator Edit: Clarified subject.
4 REPLIES 4
@Jasonwood20
Can you please explain your question?
We need more detail to better assist you with your issue.
Gary D.| Feeding Hills, MA MBG PE
Pixel Watch 3, Pixel Watch 4
Welcome to the Fitbit Community, @Jasonwood20. I'll be happy to assist with your Fitbit inquiry.
As @gdio53 mentioned, you should be more clear with your query. Do you want to discard your device and battery? I'd recommend taking them to a recycling center. You can check: How do I recycle my Fitbit device?
Replacing the batteries on a Fitbit is not something for most users as it is very hard not to destroy the circuit board in the process. I would suggest buying a new/refurbed/used/etc watch that can be returned if problems are immediately apparent. Hope that helps.
New England, USA - Various: Versa Lite, Charge 5,6, etc. Pixel 7 on 16.
I'm not sure what the original question was, but if you are handy, you can find you tube videos for replacing batteries on your model of fitbit.
