08-20-2022
07:09
06:27
DavideFitbit
08-20-2022
07:09
06:27
DavideFitbit
Anyone has experienced how to stop the notification to add card in Charge 5? I don’t intend to activate card in Charge 5 wallet, and it becomes annoying this notification prompts each time we sync the device.
Moderator edit: format
03-15-2023 07:25
04-07-2023 17:13
04-07-2023 17:13
Best Answer04-07-2023 17:30
04-07-2023 17:30
04-08-2023 06:51
04-08-2023 06:51
I have had the problem since start of Feb. I tried all the fixes, but nothing worked. buzz, buzz buzz even with notifications off. I've noticed it getting better, and today it seems to be fixed. battery only goes down to 90 overnight. I'm keeping my fingers crossed.
04-08-2023 07:01
04-08-2023 07:01
04-08-2023 21:42
04-08-2023 21:42
Yep, so it's 10:40 PM on the Saturday night before Easter Sunday and my Fitbit, a supposed, 'health tracker' is incessantly buzzing on my wrist asking me to ADD CARD to my Fitbit Wallet. The irony of this is unbelievable. Payment options and commerce is NOT the road to health and fitness. How can FITBIT (aka Google) imagine that endless electoral shocks and physical harassments is HEALTHY. Seriously. Get a grip Fitbit.
04-10-2023
18:40
09:09
DavideFitbit
04-10-2023
18:40
09:09
DavideFitbit
I've been through the process, so you don't have to. Here is what they said:
- It's a known issue, and they are "working on it". Yeah "working on it" since August last year.
- I asked for a replacement since it's completely useless. Currently, my Fitbit is showing notifications 3~5 times in one minute. It drains the battery to ~1 hour. Completely useless.
- They said I couldn't have a replacement because "It is a known issue", lol. They suggested I need to sit back and relax, waiting for the issue to be disappeared.
At this point, I wish it completely broke. What a joke 🙄
04-10-2023
18:58
09:53
DavideFitbit
04-10-2023
18:58
09:53
DavideFitbit
I also had the problem. I kept using my watch, mostly for sleep logging. Had to keep charging it several times a day. Over time, I noticed it getting better. Now I get the" add card" about once a day. My battery is back to several days between charges. Keeping my fingers crossed.
Today, everything was working fine, and then I got a rec circle of death. Some new disaster to deal with. A red circle with X in the middle.
22:07
09:57
DavideFitbit
04-12-2023
22:07
09:57
DavideFitbit
This add card notification is constantly popping up on my Fitbit 5 causing my battery to not last a day. If you cannot tell the time, monitor sleep, have to constantly have the device on charge, what it the point?
It may be ok to mark as best answer but this doesn't solve the problem. This constant add card message is draining the battery on my Fitbit charge 5, currently not lasting a day. If you cannot tell the time, monitor sleep, and have to constantly have the device on charge what it the point. This needs sorting immediately. I have no intention of adding a card to my watch. This should be an optional app that you can access not one that appears to be hounding you to use.
04-13-2023
14:39
07:38
DavideFitbit
04-13-2023
14:39
07:38
DavideFitbit
deleting user data does not fix it
Best Answer04-17-2023 12:56
04-17-2023 12:56
I am having the same issue and it is very very frustrating. My battery that used to last > 4 days now drains off in half a day. I am inclined to start posting negative reviews for charge 5 on as many platforms as i can if this is not resolved soon
04-18-2023 13:34
04-18-2023 13:34
I just decided to try fixing this issue AGAIN after months of leaving my watch sitting in the corner. While still charging, it was incredibly frustrating hearing the familiar buzz and seeing the notification about adding a card. I just tried removing the bluetooth connection, removing the watch from the account, deleting the app from my phone, restarting my phone, reinstalling the app, and resetting the watch (using the option on the watch menu). Let's see how long it lasts...
Best Answer04-18-2023 16:51
04-18-2023 16:51
Has there been any progress on this in the past four months (since Dec 2022). I continue to have the problem with my Fitbit Charge 5 randomly vibrating and telling me “Add Card Go to Fitbit mobile app and add card to Wallet”… many times a day.
04-19-2023 18:57
04-19-2023 18:57
Amazing, this issue has gone on for this long. I am a new fit bit user with the same problem. You would think this would be an easy fix. This problem degrades the quality of the experience with this device.
04-19-2023 19:51
04-19-2023 19:51
That's what is so amazing...I looked back at how far back folks have been complaining about this. As a software engineer myself, I question the competency of the engineering team to not be able to stop a notification pop up with an update. And equally interesting is the product management team who doesn't seem to care about csat being low on a public forum, enough to push engineering to fix this 😕
Best Answer04-21-2023 06:57
04-21-2023 06:57
The tranquility only lasted 30 minutes. Today, I tried logging into my account on my pc and deactivating Fitbit Pay. We'll see...
21:30
11:48
DavideFitbit
04-21-2023
21:30
11:48
DavideFitbit
I've been looking on and off for a bunch of months and your technique worked! My wife's Charge 5 would wake her up at night to setup a card and there seemed to be no solution. I did this on her app and for a few days now, she hasn't gotten a notification. I don't know if it works for everyone or forever but for the last few days, it has been blissfully quiet about the card for her! Thank you!
I have no idea what I'm doing on this forum apparently. I meant to reply to Star55's technique of acting like I'm going to setup a card in the app and then backing out of it.
04-22-2023 07:24
04-22-2023 07:24
I’ve been a Fitbit user since 2014 and have loved several Fitbits over that time. That’s why it’s so disappointing that this issue hasn’t been addressed. That said, I tried a couple of these options and only got one notice yesterday. Today I started the steps to enter a card and then backed out. Maybe this will be the charm. 🤞🏻
04-24-2023 06:44
04-24-2023 06:44
Hi Davide, where have Fitbit got to with this issue of the 'Add card notification'. It is now 4 months since you said the team were looking into it and the issue still persists. I cannot wear my Charge 5 now as it persistently vibrates with the notification both day and night and in the night wakes me up. The device is not fit for purpose and the notification also seems to drain the battery. When is a fix going to happen or how do I get a replacement? It has really put me off Fitbit and I doubt I would purchase another Fitbit product based on my experience with the Charge 5.
Best Answer04-24-2023 06:47
04-24-2023 06:47
