09-28-2021
03:07
17:27
SilviaFitbit
09-28-2021
03:07
17:27
SilviaFitbit
This is my first fitbit. I have changed the GPS to built in under the setting menu. Under exercise menu, I selected run and then I turned on the GPS but GPS seems to be always connecting and not connected. I have removed the tracker from my wrist and left it by the window and also the same. Do you know how to use the built-in GPS? I went out running this morning and it didn't recorded any GPS at all although I started the activity manually on the tracker. 😞
09-28-2021 03:19
10-14-2021 19:44
10-14-2021 19:44
One of my big reasons for purchasing was the gps feature because I do a ton of hiking, not happy to see it doesn’t work properly as a stand-alone as advertised. Also why did they do away with floors climbed? Again, as a hiker it’s a feature I relied on with my old Fitbit but it’s not on the 5.
10-15-2021 00:28
10-15-2021 00:28
My built-in GPS is working now and I don't have the problem in the video above. However, you are right it's a pity that it doesn't have floors climbed. It feels to me they try to put as many sensors and features into this tracker but all of them are half baked. The spo2 only works at night. Ecg still missing... Feel like a false advertisement actually... Fitbit doesn't sync with my Vitality insurance account... Not to mention you need to pay for fitbit subscriptions to be able to see all the metrics later... Seriously thinking to return it and get a refund.
Best Answer10-15-2021 07:29
10-15-2021 07:29
10-15-2021
17:34
06:13
10-15-2021
17:34
06:13
@estux Thanks for your input.
@ck_ and @LouiseFerrari Welcome to the Fitbit Community. Thanks for the details mentioned.
I see where your disappointment is coming from. Your feedback and comments helps us to continue improving our products and services offered.
Note that your Charge 5 has dynamic GPS, Built-in GPS and phone connected GPS. I'd like you to ensure you're following these best practices:
If you have checked the above but experience difficulties, follow these troubleshooting tips.
Also, take into consideration the Fitbit SpO2 feature is intended for general wellness purposes only and should not be used or relied on for any medical purposes. Learn more about it here.
Last but not least, keep an eye on the Fitbit News for updates on the upcoming features.
Hope this helps.
