01-20-2022 13:09
01-20-2022 13:09
Hello,
I get to the stage where it says " Your Charge 5 Inclues a 6-month Fitbit Premium Membership "
In the middle of the page is a small white letterbox that Says Please Wait with a green circling worm .
08:14
10:36
01-21-2022
08:14
10:36
Hi, welcome to the Community forums, @Kazan.
I appreciate all the details that you've shared about the inconvenience you're experiencing with the Charge 5.
Before considering other options, make sure to scroll down to the bottom of the page, since it's often required to read the entire read to be able to proceed with the next step. If you're still having trouble to complete the set up process, please complete a three pulse restart and let me know if you continue to experience the same behavior:
In addition, if the problem is related to the app, please try the following steps:
For other problem during the set up process, you can also check the steps and requirements listed in this article.
Hope this helps, I'll be around.
