05-18-2023
06:04
06:21
DavideFitbit
05-18-2023
06:04
06:21
DavideFitbit
I connect nine t Charge 5 to sync with my iPhone 14
Moderator edit: format
06:20
08:46
05-18-2023
06:20
08:46
Hi, welcome back to the Community forums, @Karenmgrill6264.
I appreciate all the information that you've shared about the difficulty you're experiencing with your Charge 5.
If you haven't done so already, please try the following steps that have been useful for other users:
In addition, I recommend that you try restarting the device using the three pulse restart method:
If you're still having any issues, let me know if you already tried all the steps listed here to resolve syncing problems, and make sure to check the compatibility requirements listed here and to keep the Fitbit app updated to the latest version available.
06-12-2023 15:10
06-12-2023 15:10
I have the same issue. I just got Fitbit charge 5 in the mail today, but it wont connect to my iphone so I am planning to return it.
Best Answer07-12-2023 07:12
07-12-2023 07:12
Welcome to the community forums, @Gatabal.
Thanks for confirming that you've been having the same issue with your Charge 5.
Could you please confirm if you're still having the same problem or if you eventually returned the device?
If you're having trouble completing the set up process, you can follow the steps in this article as well.
Best Answer07-13-2023 05:20
07-13-2023 05:20
I’ve also tried everything you’ve suggested and my charge 5 will not connect properly. If I open the app and swipe down, it connects in the moment to collect my data. But even with all options turned on, I still don’t receive alerts for texts or calls. Ever since I upgraded to the charge 5, I’ve dealt with this issue. Devices and app have even been restarted. Do I have to send this back?
