I was having problems with the sensor not working
Heart rate sensor problems.  A few weeks ago I was having problems with the sensor not working and so were a few others.  I just remembered a couple of other things the tech suggested when I spoke with her.  If u have change bands.  Go back to original and see if that helps.  All band are not made to work with heart sensor.  If u never change bands, remove your band and clean it.  It could be so dirty not letting heart sensor work correctly.  Hope this helps.
1 REPLY 1
Hi, thank you for sharing this information about the steps that worked for you with the problem you mentioned with the heart rate sensor, @SunsetRunner.
I'm sure this will be useful for other users as well. Let me know if you continue to experience any problem to track your heart rate.
I'll be around.
