06-21-2024
04:39
09:47
06-21-2024
04:39
09:47
Am I the only one having this issue with the battery %, which is not clear and visible, on the second screen of my Fitbit Charge 5?
As said, it's on the second screen, where there is a summary of the information, including the battery % at the top of it.
Unfortunately, the battery percentage font is small and in mid-grey on a black background, which makes it not visible, in all conditions, and especially in the daylight.
I just wanted to ask if it would be possible to make it white, like all the other info on the same screen; or, for example, yellow or bright green, like the battery icon. IMO, this quick, small change to the font colour would be a great improvement, as that’s the only place where the battery % info is available on the Fitbit UI (rather than in the App), and it’s bad that is not visible.
Here is a photo of the screen, where I pointed the battery % with a yellow line, to clarify my point. Try to imagine looking at it, small on your wrist, on a sunny day: I cannot read it.
Hope the developers can help me with this request.
Thanks
Best Answer06-21-2024 14:35
06-21-2024 14:35
Hello @IF.
Thank you for your feedback & suggestion.
You might want to consider adding your vote & comments to this feature request in the Product Feedback forum: Enlarge & brighten battery life indicator on the Charge 5 (<-- click link). The developers monitor this forum to see what features are being requested for potential future implementation.
