01-10-2023 08:03
01-10-2023 08:03
My Charge 5, brand new in December, is erratic in tracking running/walking. The steps are counted correctly but the "Days of Exercise" do not always count. An hour+ walk of nearly 10,000 steps yesterday did not appear. Nothing else has changed. There does not seem to be a pattern.
Best Answer01-10-2023 14:23
01-10-2023 14:23
Hi @PDB-Mequon. I would suggest you start by resetting your Charge 5 tracker, and clearing the app ache, on your mobile device, for your Fitbit app.
How do I restart my Fitbit device?
CharlesKn | Mid-Atlantic, USA
60+, strength and cardio
Charge 5, Android, Windows
01-10-2023 14:23
Best Answer01-14-2023 10:13
01-14-2023 10:13
I followed your instructions and it seems to have helped. There were several days before when no activity was tracked even though the step counts were over 10,000. The mileage was tracked and all other functions were tracked and seemed correct.
Thanks
Best Answer01-14-2023 13:48
01-14-2023 13:48
Awesome @PDB-Mequon! I'm glad it helped.
Best Answer03-02-2023 12:38
03-02-2023 12:38
should I reset the charge 5 tracker every day? The charge 5 counts steps correctly when I walk big distancies; today the app thinks that I didn't walk enough between 9 and 11, charge 5 shows that I walked enough.
Best Answer03-02-2023 13:46
03-02-2023 13:46
@RosaFischer I would hope you wouldn't need to do that. If that is the case, then there is another issue.
