07-19-2022 11:26 - edited 07-20-2022 13:42
We’re excited to announce that a firmware update for Charge 5. Some of you might already have this update available. If you installed it, let us know what you think!
We release updates to customers in phases. If you don’t see it, check the Fitbit app in a few days, and you’ll see a message when you can install the update. We appreciate your patience while we get this update to all of our customers.
WHAT’S NEW AND FIXED
See What's changed in the latest Fitbit device update? for release notes.
HOW DO I UPDATE?
See How do I update my Fitbit device? for step-by-step instructions for updating your Charge 5. If you run into difficulty updating, see Why can't I update my Fitbit device?.
We’re interested in hearing your feedback on this update! Let us know what you like! If you encounter unexpected behavior during or after your update, please post the details below.
07-29-2022 07:50
07-29-2022 07:50
Yes I wouldn’t update if yours is working well, the thing is a lot of people have been waiting for the update, as I have, as the battery only lasts a few hours?!
07-29-2022 09:43
07-29-2022 09:43
Still doesn't work. Hurry up and wait says Fitbit! Help is coming. Sad
07-29-2022 09:55
07-29-2022 09:55
07-29-2022 09:56
07-29-2022 09:56
Mine did this before the update as did a lot of people's if you look on the community The update that was meant to fix it didn't do a thing
07-29-2022 09:56
07-29-2022 09:56
07-29-2022 09:57
07-29-2022 09:57
07-29-2022
10:05
13:01
DavideFitbit
07-29-2022
10:05
13:01
DavideFitbit
Your sad face in the mirror 😫 isn't as sad as it would be if your Charge 5 quit working after the update like some other people's did. Just be Beamin that it works and maybe someday a new face 🤓 will appear and it won't be a 😱 face but a 😁 face!
Kinda like every fall when you set the clocks back and an hour is lost except it happens every day.
Good luck. I hope they are able to get it resolved for you.
Oh no. I'm sorry that happened to you. You would think that with all these people reporting problems they would make the update unavailable to others until they have figured out what is causing the problems people are reporting. Just seems to be the smart thing to do. Someone needs to tell them, "when you find yourself in a hole, quit digging!"
07-29-2022 10:18
07-29-2022 10:18
Update went like a charm. 🙂
No new clock faces. 😕
But wait! Fitbit never said that there really are new clock faces.
They just suggested to find new clock faces. Maybe in a sense like to find easter eggs at Easter? You cannot be sure that there are any. But you can nevertheless try to find some ... 🤔
07-29-2022 10:19
07-29-2022 10:19
07-29-2022 10:24
07-29-2022 10:24
07-29-2022 10:30
07-29-2022 10:30
That's true. Maybe that's the purpose of the mystery regarding the new clock faces. They don't want to show us a screenshot of the new faces, because we are supposed to find them (and because they may or may not exist).
Now that I've been told there could be new ones though I'm even more unsatisfied with the ones we have, which I surprised is possible considering how lackluster
07-29-2022 10:31
07-29-2022 10:31
@Talahthas , if it is the case I think the note shouldn't list here in "What's Changed..." as it is not a change, isn't it?
07-29-2022 10:32
07-29-2022 10:32
The fix is to throw it away and buy a different brand. Seriously.
07-29-2022 10:36
07-29-2022 10:36
I am happy for you. I never updated and still have not received the update, but a month ago when I went to charge my 5 is when this all began. It is a glitch in the product and has nothing to do with anything I did. Hopefully, they can resolve, but per Fitbit I have not updated or received any update to date. Others have indicated the same thing.
07-29-2022 10:51
07-29-2022 10:51
07-29-2022 10:54
07-29-2022 10:54
I am not experiencing half of the problems that others are but my after speaking with several advisors and reading other people's experiences, I'm shocked that such a big company can treat their customers so poorly. People unable to use their products properly (or at all!) Fitbit should be jumping through hoops to correct the issue.
I want to return my Fitbit and never purchase anything from this company again!
07-29-2022 10:57
07-29-2022 10:57
07-29-2022 11:05
07-29-2022 11:05
07-29-2022
11:16
12:59
DavideFitbit
07-29-2022
11:16
12:59
DavideFitbit
Hi guys. When I started this post it was because the update failed. Then I
saw the posts about problems from the update. Now my for charge5 ha updated
itself and now the same problems. Won't hold a charge, no standup reminder.
I bought this phone in June!!!!!
thank you.
07-29-2022 11:37
07-29-2022 11:37
@SunsetRunner
<Some folks, like you, report that the update went fine and your Charge 5 works fine after the update. Other's report problems after the update >
Wait fot it ... 😄
My Charge5 had always worked ok. My update went well. No problems. Device worked fine for about 24 hours.
Then the hell broke loose. First the battery drained, then the display vent crazy and then black. I ended up with a device, that is connected to the phone app, but does nothing else.
It could also be, that some specific sequence of actions by the user triggeres the error. Like swimming and starting GPS????
